6.5 injection pump
Old Mar 10, 2009 | 05:52 PM
zach_west's Avatar
Default 6.5 injection pump
I need help in timing my injection pump. My teacher was unsure about how to do it and i was wondering if anybody could help us out on this one. It's a '98 chevy. thank you
Old Mar 10, 2009 | 06:07 PM
wildbill's Avatar
To cam gear will have two marks on it, one for the injector pump, and the other for the crankshaft (both marks are a different shape). Now, your going to have to time the pump to cam first. Line the marks till the are pointing straight at each other, then turn the cam 1/4 turn to the right until both marks point to the right side (facing the front) at a level. A 2nd mark should be pointing straight down. If pointing straight up, you got the pump and cam timed wrong. If it's straight down, can time the cam to crank.
Old Mar 10, 2009 | 06:13 PM
wildbill's Avatar
Now to time when the advance/retard fueling. Once you bolt the injection pump to the engine, and the pump gear (be a one way bolt pattern), should be a line on the pump flange, and the flange on the engine. Make sure both marks are pointing at each other. Or if you prefer to have it advanced a little, pry the pump toward the number one bank, till you get about a line, 2 lines max past the mark on the engine.
Old Mar 14, 2009 | 11:39 PM
wildbill's Avatar
How'd it work out??
Old Mar 22, 2009 | 10:04 AM
MRaynor's Avatar
Any updates?
Old Mar 25, 2009 | 05:03 AM
wildbill's Avatar
Closing due to 15 days w/o an update. They can reopen if need be.
Dbleo351
Nov 20, 2016 09:34 AM
moneypitk5
Feb 12, 2015 11:01 AM
airspeed181
Jan 19, 2015 09:00 PM
letters4and18
Dec 11, 2014 12:03 PM
rtbcoop
Nov 29, 2014 11:33 PM
