Duramax losing prime
Old Feb 24, 2009 | 05:09 PM
fwdbite's Avatar
Default Duramax losing prime
I've been having trouble with My 04 duramax losing its prime. It shuts down and I have to pump the fuel filter primer to get it to start again. Also Ifr it sits for awhile it wont start till I bleed it off then prime it. Fuel filter has come loose twice, cant seem to keep It tight. But it will lose its prime even if the filter is still tight. Could there be anything major that is causing this?
Old Feb 24, 2009 | 05:47 PM
Diesel-N-Dust's Avatar
Mayde the bleeder screw. Or bad injectors.
Old Feb 24, 2009 | 07:20 PM
dhardy1357's Avatar
my 01 was doing something simialr to this. the bleed off screw on the fuel filter has an o-ring that had gone bad and it was causing it to suck air into the line. maybe this helps
my 01 was doing something simialr. the bleed off screw on the fuel filter has an o-ring that had gone bad and was causing it to suck air into the line. hope this helps
Last edited by dhardy1357; Feb 24, 2009 at 07:20 PM. Reason: Automerged Doublepost
Old Feb 24, 2009 | 08:01 PM
Mr. Duck's Avatar
How does it run when you put your foot into it?
High end fourth gear should tell the tale, if it lags or stumbles it could be the filter or bleeder screw.
The filter on my LBZ used too loosen off, I really wrench it on now and it's all good.
The filter system on the duramax is a suction system and it will try to suck air in anywhere it can.
Old Feb 26, 2009 | 04:25 AM
fwdbite's Avatar
Thanks for the reply's, It seems to run fine untill it sits for a bit after it been ran for awhile. Its been in my driveway now for two days and is still running fine. Seems like after I run it for a while it acts up. I'll try tightening the filter a little more and check the bleeder screw. Thanks again
Old Feb 27, 2009 | 12:15 PM
wildbill's Avatar
Old Mar 3, 2009 | 05:22 PM
wildbill's Avatar
Any updates??
Old Mar 7, 2009 | 08:41 PM
wildbill's Avatar
Closed: last activity 02-26-2009 03:25 AM
jt19
Aug 20, 2015 12:18 AM
jt19
Jul 13, 2015 03:06 PM
Nick3093
10
Mar 22, 2015 09:46 AM
Baradium
Mar 9, 2015 07:15 PM
duramaxtuner
Dec 10, 2014 01:24 PM
