Duramax wont start
Old Feb 21, 2009 | 09:58 AM
fwdbite's Avatar
Default Duramax wont start
For the secont time in a month my 2004 duramax wont start. It stalled on me while I was slowing down for a stop sign and is dead in the water. I was able to get it to fire a couple times by loosening the priming screew and priming it with the filter pump, but it would only run for maybe 30 seconds. It was about 10 above zero out so I wouldn't think that that would be the problem? I put some degelling stuff in it and put it in the garage but it still wont start. It seems to be getting some air from somewhere because when I blead it off when priming it some air will come out. This happened about a month ago and I changed the feul filter and it took care of the problem. Any thoughts????
Thanks in advance, Brad
Old Feb 21, 2009 | 10:35 AM
2500HeavyDuty's Avatar
is there a leak on the fuel filter housing?
Whit's Avatar
Site Mascot
sounds like yer getting air somewhere............check all yer connections and re-prime
Old Feb 21, 2009 | 10:57 AM
fwdbite's Avatar
Where Should I start checking for leaks? I did change filter a few weeks ago but was pretty careful putting the new one on. I have only ran It for a few days since. I thought maybe my fuel was gelling and then sucking air from tank but that dont seem to be the problem. Should I get a new filter and put it on?
Old Feb 21, 2009 | 03:45 PM
What kind of upgrades are you running?
Old Feb 21, 2009 | 06:05 PM
fwdbite's Avatar
Thanks for all the help. I changed the fuel filter and primed it. It started up and seems OK. I just wish I could figure out what the problem was. It did seem to be getting air somehow from somewhere, The filter was a little loose but not bad. I guess I'll have to run it and see. there is no upgrades on the truck its bone stock. Thanks again, I'll be back if needed, Great site
Old Feb 21, 2009 | 06:09 PM
sounds good. ima close the thread. you can choose to re-open it if you like if the problem continues
Cavnar
Sep 9, 2015 07:18 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
BoostedSix
Nov 7, 2014 04:54 PM
