1993 Chevy 6.5 turbo stalling problem
Old Feb 18, 2009 | 01:35 PM
bigcatff7's Avatar
Default 1993 Chevy 6.5 turbo stalling problem
I have a 1993 6.5 turbo after it has ran for about a half hour it will stall,it will start back up but stall 10 seconds later,after letting it sit for a hour or so it will start back up fine.
I have changed the lift pump,fuel filter and oil pressure switch so far does this sound like a injection pump problem?
I just bought this truck with 180xxx on it and I noticed someone has replaced the fuel lines with rubber could this cause a problem also I have removed the gas cap to see if there was any pressure and there was none any help would be appreciated thanks...
Old Feb 19, 2009 | 06:31 PM
wildbill's Avatar
Thinking you got a hole in the fuel line between the tank and the lift pump. Pressure the tank up to 10 lbs and see if any fuel leaks out.
Old Feb 24, 2009 | 10:04 PM
wildbill's Avatar
Any updates??
Old Feb 27, 2009 | 12:02 PM
wildbill's Avatar
Any luck??
Old Mar 1, 2009 | 12:47 PM
wildbill's Avatar
Closing due to lack of an update. If need be, thread starter can reopen.
burndiesel
10
Feb 7, 2023 01:15 AM
Hogridenfool
Nov 20, 2017 04:37 PM
old chevy
Sep 2, 2015 08:42 AM
glasspack
Jul 29, 2015 11:04 AM
Snoobly
Dec 11, 2014 11:59 AM
