6.0 spins but no start after driving
Old Feb 13, 2009 | 07:16 PM
eaglesoars's Avatar
Default 6.0 spins but no start after driving
I drove my truck (F350 6.0 2003) while working and cut it off when I finished. It would not restart a few minites later. The next day I tried again and it would only turn over no start. The next day again I tried to start. It sounded a little more promising and aftert a burst of ignition it started. This same procedure repeated its self.
Old Feb 13, 2009 | 11:10 PM
1Tondiesel's Avatar
Have you checked your fuel flow? I had a lift pump go out on mine and had similar symptoms.
Old Feb 14, 2009 | 12:55 AM
Diesel Nut's Avatar
Oil Level? Good? Low? How long since oil change?
Codes?
Fuel pressure is a big thing on 6.0L trucks. Check fuel pressure at a head. If its below 40psi, start looking for a restriction. Fuel filter is an obvious place to start. Next, check that your fuel pump is coming on, and if so, is it noisy? Maybe the strainer in the tank has and issue.
Old Feb 19, 2009 | 06:33 PM
wildbill's Avatar
Any updates??
Old Feb 24, 2009 | 10:03 PM
wildbill's Avatar
Closing due to one time post.
Cavnar
Sep 9, 2015 07:18 PM
Accubuck
May 7, 2015 04:46 PM
cjgregory
Mar 31, 2015 01:45 PM
irozchris
Mar 14, 2015 11:16 PM
thumperf350
Jan 8, 2015 12:55 AM
