01 dodge clutch bleeding help
Old Feb 10, 2009 | 10:30 PM
cruiserfj45's Avatar
Default 01 dodge clutch bleeding help
I installed a new clutch master cyl and now I found there is no bleeder screw on it. So how do I bleed the system?
Old Feb 11, 2009 | 01:13 AM
2500HeavyDuty's Avatar
bump, i got nuttin for ya bud sorry
Old Feb 11, 2009 | 04:40 PM
kazairl's Avatar
If you take the slave cylinder off the tranny, you can stroke it in and out which will help. Then you'll have to pump the clutch A LOT to get the air out. It's a PITA.
The best way would be to find a vaccum pump and drill and tap your cap for a fitting and then pull a vaccum on the system. I'm currently coping with this problem as well. I
ll let you know if I come up with something that works better.
Old Feb 11, 2009 | 05:11 PM
cummins24's Avatar
When I replaced mine I ran into the same thing and pumped the clutch alot!! It worked though.
Old Feb 13, 2009 | 07:55 AM
wildbill's Avatar
Any chance of loosening the line at the clutch end to bleed it off?? Granted it's going to take an extra pair of shoes to accomplish the task.
Old Feb 14, 2009 | 01:02 AM
Diesel Nut's Avatar
Normally the clutch hydraulics are replaced as a unit, they come complete and pre filled and bled. The only way to bleed them that I am aware of is to remove the slave (push out roll pin, remove tube), prefill the slave and bleed by GENTLY moving SHORT strokes until there is no air bubbles. Next, get a can or drip pan and have some one fill the reservior on the master and keep it full untill no mor air comes out the bottom into the drip pan. Now, while keeping the master full you need to attach your bled slave and reinstall the roll pin.
Next, you need to SLOWLY cycle the slave with your hand to pump the air out of the system to the slave reservior. This will take some time to do.
Old Feb 17, 2009 | 02:16 AM
So from the factory the whole system is sealed and not serviceable and replaced as a whole, master cyl, slave cyl, hydraulic line and clutch switch. I had to remove the slave cyl fish it around so the line went straight up, no where for air pockets to sit and let it sit over night. Then pumped the slave cyl and I finely got it working. I hate dodge
Old Feb 19, 2009 | 06:36 PM
wildbill's Avatar
Any updates??
Old Feb 20, 2009 | 08:38 AM
kazairl's Avatar
well. I don't know about him but I tried the above^ and it worked pretty good. Except I didn't have time to let it sit overnight so I pulled a vaccum on it for 25 mins. Pumped the slave a few times and it seems to be working alright now.
Old Feb 24, 2009 | 10:09 PM
wildbill's Avatar
Any luck??
Turbo67
Jul 25, 2015 02:26 PM
RedChevy44
Apr 21, 2015 05:47 AM
Dec 29, 2014 10:20 AM
Dec 12, 2014 12:30 PM
Nov 3, 2014 08:10 AM
