timing case and ticking noise
Old Feb 9, 2009 | 11:30 PM
12valvetater's Avatar
Unhappy timing case and ticking noise
Ever since I have had the truck it has leaked oil and had an odd ticking noise not really that loud though. The other day i was under it wiping the crud of the gear case and I found a crack in it. If the crack isn't t bad can the case be fixed somehow or do I just need to find a new/used one? Also it has a weird tick kind of sounds like manifold gasket or valve adjustment. Has any body heard this before? the oil is pretty black so i guess its getting some blowby. Could this noise be coming from piston slap? sorry about the long post but i need help!
Old Feb 9, 2009 | 11:50 PM
stkdram55's Avatar
sounds like the killer dowel pin come out
Old Feb 10, 2009 | 12:17 AM
94cummins12v's Avatar
yep it does
piuston slap, piston slap, piston slap im currently rebuilding mine because of that
Last edited by 94cummins12v; Feb 10, 2009 at 12:17 AM. Reason: Automerged Doublepost
Old Feb 10, 2009 | 09:45 AM
How can I check to make sure that is in fact piston slap. If it is where is a good place to find pistons im debating on putting marine pistons in.
Old Feb 10, 2009 | 10:25 AM
pull the head to check i got a rebuild kit for $650 comes with pistons, wristpins, all bearings, rod bearings, main bearings, seals from top to bottom
Old Feb 10, 2009 | 10:28 AM
Whit's Avatar
Site Mascot
sounds like yer KPD fell out to me............especially if yer timing case is cracked and leaking oil
Old Feb 10, 2009 | 03:22 PM
Where did you get the kit from?
Old Feb 13, 2009 | 07:50 AM
wildbill's Avatar
Cummins carries all the parts. A lot less than the dealer in fact.
Old Feb 16, 2009 | 08:31 AM
wildbill's Avatar
What's the good word!!
Old Feb 24, 2009 | 09:57 PM
wildbill's Avatar
Any updates??
