Need help fast on ball joint/hub removal
Old May 19, 2007 | 07:54 PM
01Diesel Bomb's Avatar
Default Need help fast on ball joint/hub removal
I have been fighting with getting the hub to seperate from the knukle on a 01 ram 2500 but I can not get to budge at all!!! Is their a trick, or some thing I am doing wrong or missing I tried a hub puller and hitting it but NOTHING works I found a how to but it is for a ram 1500 any help would be kool.
Old May 19, 2007 | 08:03 PM
Uncle Bubba's Avatar
A deepwell socket between the hub and axle housing. With the front end in the air, start the truck and then turn the steering wheel. the power steering will pop it right out as long as you have all the bolts loose. Your gonna fight yourself to death with a puller.
If this doens't work you still got bolts holdin it.
Old May 19, 2007 | 08:40 PM
I cant really find a place the axle is in the way or should the axle be out by now?
Old May 19, 2007 | 08:45 PM
Should be a spot right up there in the knuckle/U-joint. Just put it between that U-joint and the housing behind it. You might need somebody to hold it while you turn the steering wheel into it. Just make sure they move before you put any pressure on it cause it will pop out when it goes..
Old May 20, 2007 | 12:52 AM
Thank god for the internet that worked thanks for the help..
Old May 20, 2007 | 12:55 AM
Same place I learned it, we just pass it on the same way somebody was nice enough to do for us. Congrats on savin a few hundred dollars.
LawdawgSHPD
Aug 21, 2015 06:23 PM
oznation
May 26, 2015 09:23 AM
nickpro902
Mar 14, 2015 08:46 PM
99RAMS
Tire, Wheel & Suspension
Jan 25, 2015 11:31 PM
A Bit Hick
Oct 23, 2014 03:22 PM
