Towing and Hauling Diesel Discussions of Towing and Hauling Practices , Techniques , Tips Including Trailers , Campers , 5th Wheels , Goosenecks , Boats and More
2nd gen cummins tow set up - whatcha got?
Old Jan 19, 2009 | 02:13 PM
Kawi1500Vortex2's Avatar
Default 2nd gen cummins tow set up - whatcha got?
just curious what you guys are running for towing your trailers - and what the total combined weight is - and what your milage is on flat ground with your set up?
thanks in advance
don
ps - my current set up is simple: i bought the truck that rammed the lambo in the latest bat man movie. no kiddin, the exact truck that christian bale got rammed with in the movie. took that, fixed the frt end and -
put a #10 plate in it (pretty close to full forward)
set of 5x12 inj
a 3800# double disc clutch
4" ex
and a good air filter
the truck rips
milage is not great 15 mpg best at 22,000# total
whatcha got?
and hows it work?
thanks, don
Old Jul 28, 2009 | 01:45 PM
AF1CUMMINS's Avatar
Well you can pretty much look at my signature and see what I've got done to my truck. I pulled a 35' gooseneck with a 20' Conex/Shipping container, whatever you wanna call it and all my house stuff inside it. I moved from Seattle, WA to Sumter, SC and averaged about 9 MPG. However, flat ground comin across southern Wyoming, then Nebraska and Kansas if I took it I was gettin 10 and close to 11 in some places. With a full tank of fuel on the scales with truck, trailer and load I was right at 24K pounds. Hope this helps you some.
One more note you might need. I THINK, not sure, but THINK I've either got 4.56 or 4.10 gears. I know that at about 75 or 80 mph with the 35" tires I'm cruisin at right at or just over 2100 RPMs.
Old Aug 12, 2009 | 12:59 PM
displacedtexan's Avatar
100 plate, 16.5* 370s modded AFC (full fuel at 30psi with a stok 215 gov spring)
BHAF, heatsheild, straight 3"
Total weight approx 1300# mixed driving (mostly city) good bit of idleing, 15mpg
And didn't you go off on people not using their real names for screen names on another forum? I at least use the same name everywhere...
Old Aug 12, 2009 | 01:09 PM
94cummins12v's Avatar
100 plate, 370 injectors(for now) 191 delivery valves, 4k gov spring, super phat shaft 62/71/14 turbo, 4" to 5" exhaust, water/meth injection, valair 13" 6speed ceramic clutch, 16.5* timing, 3.54 gears pull mostly 35" goosneck dovetail with equipment. most common is bobcat with atchment gross trailer weight anywere from 8k to 16k normal days around 14mgh hiway loaded
cutthroatxxx
Feb 11, 2015 07:50 PM
Cumminsfreak24
Jan 21, 2015 09:10 AM
bigbrowngoat
Jan 7, 2015 06:43 PM
myago92
Oct 17, 2014 08:50 AM
Jthompson_32
Oct 5, 2014 09:51 PM
