Chevy/GMC Duramax 07.5 -10 LMM Discussion of Chevy and GMC Trucks with LMM Duramax Turbo Diesel Engines
Boost PSI range? LMM 08
Old Jan 15, 2009 | 03:02 PM
madmanwithmouse's Avatar
Default Boost PSI range? LMM 08
I been watchin my boost psi on my dash hawk, and i think i found the hangnail in the 08 MPG..... under full load with a 30000lbs load going up a 6% incline i only see a max of 20psi boost and this is with a 125hp tune installed, also keeping my egt around 1300deg. I rember on the dodge 5.9 it was ez to get 30psi. Im no rocket sicentest, but seems to me that it should be around 30-35?
Old Jan 15, 2009 | 03:56 PM
GmcLbz's Avatar
Site Sponsor - Upstate Diesel Performance
It all depends on tuning, but 20 seems a bit low. You might want to try a mechanical to see how accurate the dash hawk is. I think you'll find you are closer to 30.
Old Jan 15, 2009 | 06:23 PM
humm, i hope your right. ill have to check into that.
is there a spot somewhere tapped for boost?
Old Feb 10, 2009 | 04:20 PM
rcpd34's Avatar
I would have guessed around 25.
Old Feb 11, 2009 | 12:30 AM
2500HeavyDuty's Avatar
yeah, the boost is electonicly controlled by what programming it has in there. you can call them and ask them what they set it to
even with my lb7 i dont even get close to 35 psi. them turbos are a bit bigger than the stock dodge ones
Old Feb 12, 2009 | 01:40 PM
Meyer Performance's Avatar
You should be around 25-28 psi, and deoending what tune you are running not much over 30-32.
Tyler
Old Feb 18, 2009 | 03:01 AM
hummm, well the highest ive ever seen it at was 28psi, but I had to shut down due to egts very soon afterwards.
Old Feb 25, 2009 | 11:14 PM
hondarider552's Avatar
seems too low for being tuned.
Old May 13, 2009 | 03:49 PM
coker6303's Avatar
I'm pushing 31psi on a slightly modified (EFI Live) quadzilla 50hp tune under hard accelleration. I'm thinking your gauge is off as well. These trucks hit 30-32 pretty consistently when tuned, anything over that is pushing limits of the stock turbo.
Feb 23, 2015 06:20 PM
chaoticape
Jan 4, 2015 05:35 PM
Tsgbk9
Dec 23, 2014 11:54 AM
joshkhouse80
Nov 21, 2014 01:17 AM
offroad00
24
Oct 23, 2014 03:28 PM
