2000 5.9 24V - Wont Start
Old Jan 8, 2009 | 07:12 PM
wardcleaver2001's Avatar
Heart 2000 5.9 24V - Wont Start
I am new at this.... I have 2000 5.9 24V with 139,000 miles. Replaced the VP 44 and lift pump July of 2007 due to bad lift pump (@ 107,000 miles). No modifications done via chips, turbos, etc.
Now getting a P0253 code from scan tool. No Check engine light comes on. Truck will not crank. "Wait to start" comes on then goes out like normal.
Power on to ACC 3x shows only P1693 code on dash.
When VP44 went bad, truck got the 1688 code and would crank but not start.
Any thoughts ?
Old Jan 8, 2009 | 07:18 PM
DB Admin's Avatar
Banned
You say the truck wont Crank , Wont even Turn Over ?
Old Jan 8, 2009 | 07:24 PM
Nothing. I did the warm-up as usual "WAIT TO START" went out.... nothing when key is turned. No click or anything.
I tried several times with no luck...
Old Jan 8, 2009 | 09:28 PM
busta's Avatar
hmm injection pump metering control A low
contacts in starter could be reason not turning over or maybe got a short
kinda new at this myself so just guessing myself
Old Jan 8, 2009 | 09:39 PM
Whit's Avatar
Site Mascot
I agree with Busta...............also check batt cables and connections
Old Jan 10, 2009 | 09:11 AM
wildbill's Avatar
Any updates??
Old Jan 10, 2009 | 01:15 PM
wyoranch's Avatar
Is it manual or auto? If its manual it may be the switch on the clutch that keeps you from cranking it without the clutch in. Or if its auto could be the same thing, you could try starting it in neutral
Old Jan 17, 2009 | 03:08 PM
wildbill's Avatar
P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector) = VP44 needs replaced??
P1693 is a companion code.
Old Jan 19, 2009 | 09:14 AM
Closed due to lack of response.
Mac1997
Jul 13, 2015 05:08 AM
ronstop
Feb 26, 2015 09:48 AM
Downd19
Dec 30, 2014 02:49 PM
texasd
5.9L CR Performance
8
Dec 20, 2014 07:39 PM
mpenny671
Oct 7, 2014 01:18 AM
