Ford Truck and Powerstroke Turbo Diesel Forum Discussion of General Topics related to All Ford Trucks as well as the Diesels in them
4.4 60* v8 for the f-150
Old Jan 1, 2009 | 09:19 PM
redneckbuckeye's Avatar
Default 4.4 60* v8 for the f-150
I just read that the 4.4 60 degree v8 diesel for the f150 will have belt driven camshafts/per diesel power mag, that seems like under engineering to me. Why not use timing chain, or better yet a gear set?
Old Jan 2, 2009 | 03:52 PM
dozerboy's Avatar
So you have to being it in for a new timing belt every 30K. I thought read the 4.4 was not going to be made now?
Old Jan 2, 2009 | 04:12 PM
dieseldude03's Avatar
The way I understand it, the 4.4L is a larger version of the 3.9L Lion V-8 diesel Land Rover has used in Europe for several years.
According to Pickuptrucks.com, it's a twin-turbo engine: To be built in Mexico, the 4.4-liter V-8 was to be offered in production F-150s by late 2009, and by 2011 it was expected to be the base diesel engine in Ford's Super Duty pickups. Power ratings are expected to be at least 340 horsepower and 430 pounds-feet of torque. Fuel economy is expected to be as much as 20 percent higher than Ford’s 5.4-liter V-8 gasoline engine.
Due to economic reasons, Ford has now "postponed indefinitely" it's release.
Old Jan 2, 2009 | 06:12 PM
gunman41mag's Avatar
Moderator
Hey redneckbuckeye, I like the idea about the gears, I think the gears would last longer then the timing chain, not that I have ever had a timing chain break on me !!!
Old Jan 2, 2009 | 11:46 PM
BLACK_06POWERSTROKE's Avatar
that cant be true atleast i hope it isnt
Old Jan 3, 2009 | 09:04 AM
Sea97Stroker's Avatar
I thought they shelved the 1/2 ton diesels??? If not ..hell yeah!!! Glad to see it is finally going to happen.
Old Jan 3, 2009 | 01:41 PM
According to Diesel power mag
4.4 60-degree V8
310hp/516ftlb torque
acceleration similar to the 5.4L gas engine
common rail fueling with piezo injectors
twin turbos
catalytic converter and DPF
compacted graphite iron engine block
selective catalytic reduction through the use of liquid urea
six speed ZF automatic trans
9 3/4" ring gear and seven lug wheels similar to the semi floating rear axle of 7700 series f250
according to a poster secretly filmed at a closed viewing, the diesel engine is said to have 20% better fuel millage compared to the 5.4L gas engine.
Article said that Ford will be the last of the big three to launch the 1/2 ton diesel pick up, and GM will be the first.
Old Jan 3, 2009 | 07:03 PM
dozerboy's Avatar
I can see them in the 1/2 tons and SUVs, but putting them in the F-250s+? I would think the engine would have a low longevity at those GVWRs. That might not be much of a problem for leases and trucks the get traded in, but it would affect resale.
Old Jan 3, 2009 | 07:12 PM
bobcat67's Avatar
wow, that doesn't make any sense why would you put timing belts on em? that's just dumb i hope that's not correct, oh well, cummins won't do that so i'm stickin with that
Old Jan 3, 2009 | 11:48 PM
The new 5.0 Cummins uses a chain driven overhead cam.
2500HeavyDuty
Price Quote - Request A Price
Aug 11, 2015 04:31 PM
Dslmech600
Aug 11, 2015 09:39 AM
JesseJames288
5.9L 24V Performance
Jun 4, 2015 06:35 AM
2ndcummins1
Mar 9, 2015 10:01 AM
cass_epp
Oct 28, 2014 02:49 AM
