suspension question
Old Dec 15, 2008 | 08:53 PM
tomc983's Avatar
Default suspension question
i have a 03 chevy 2500hd ext cab i want to do a leveling kit. need some opions on it a ready lift with what size tire would be smart and whats the risk? and ride like and if any one has some pics id really like to see
Old Dec 15, 2008 | 09:03 PM
TCU Fan's Avatar
Aaron
Cognito makes a nice kit that you can run 33's on. Or you can just go with a full 6" lift and run some 35's. I do not have this truck anymore but I had an RCD 6" with 35's on it at the time this picture was taken.
Old Dec 15, 2008 | 09:21 PM
Rttoys's Avatar
For the inexpensive solution, 2" blocks in the rear available through GM and cranking the t-bars will get you a nice stance and still a good ride. Stock wheels with 285's is common or swing as high as my 305/50-20s or 305/55-20s.
Attached Thumbnails suspension question-dsc00853.jpg   suspension question-fag-weekend-2005-012.jpg   suspension question-p1010516.jpg   suspension question-ppihc-08-006.jpg
Old Dec 24, 2008 | 07:28 PM
tomc983's Avatar
i looked into the cognito 2-3in kit not sure if i want to do it yet both trucks look sweet i need my truck to be a bit higher went from a f350 with a 6in to a stock duramax dont want to lift it but needs somthin
Old Dec 31, 2008 | 10:19 PM
K50's Avatar
K50
On that note, where can I get a torsion bar cranking tool? Does it make sense to get a shop to do it or would it be cheaper to buy the tool and only use it once? No one rents these sort of tools do they? (sorry for so many questions)
Old Jan 1, 2009 | 08:27 AM
Rttoys's Avatar
To crank the t-bars, it only takes a 15mm or an 18mm (can't remember the exact size right now) socket and ratchet.
Old Jan 1, 2009 | 02:46 PM
dozerboy's Avatar
You can use a gear puller to unload the tbar, but be very careful. The tool is ~$100 not really worth the cost if you not adjusting them all the time. No one rents them any more that I know of for sure Merchant Automotive use to. Most people just jack the truck up and get the front tire off the ground. That takes a lot of the load off the bolts and penetrating oil.
Old Jan 1, 2009 | 04:03 PM
2500HeavyDuty's Avatar
18mm
carid
Diesel Bombers Sponsors
Apr 22, 2015 09:28 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
Twelve valves
Price Quote - Request A Price
Jan 18, 2015 05:36 AM
tumble72
9
Nov 10, 2014 09:06 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
