what am I missing
Old Dec 10, 2008 | 11:16 AM
bfrizzell16's Avatar
Default what am I missing
I have a 1983 f 250 6.9 I just picked up it would start just fine with a shot of ether so since the wait to start light never came on I knew something wasn't right so I put new glow plugs and new relay the wait to start light still dose not come on, but now I can bypass the relay and cont to 5 and she fires right up but why dose the wait to start light not come on,when I bypass the relay the light comes on so I know the light works what am I missing
Old Dec 10, 2008 | 12:16 PM
wildbill's Avatar
There is a controller that reads off of the coolant temp to determine whether or not glow plug use is required. You may still be able to get a new on from Ford, but they are a little spendy. Last I checked on one for a GM 5.7L diesel (pretty much the same as what your Ford uses) they were about $250.
Old Dec 10, 2008 | 12:31 PM
where is that located at and how do I check it
Old Dec 10, 2008 | 12:35 PM
wildbill's Avatar
Usually on the back of the engine, drivers side. It may be threaded into a cylinder head, might be plastic, bout an inch in diameter.
Old Dec 16, 2008 | 08:57 AM
wildbill's Avatar
Any updates?
Old Dec 22, 2008 | 08:10 AM
wildbill's Avatar
What's the good word?
Old Dec 26, 2008 | 05:44 PM
wildbill's Avatar
Thread starter can reopen if he/she desires, as we can assume the problem has been fixed.
caffeyonthebeach
99-03 7.3L Performance
Jan 21, 2016 07:36 PM
Sep 30, 2015 12:40 AM
dawnrogerl
Jan 21, 2015 09:10 AM
jrsavoie
Shade Tree , Pro-Mechanics & Fabrication
Nov 25, 2014 09:48 AM
Stick_Welder
9
Oct 24, 2014 04:10 AM
