03-07 Cummins CR 24V 5.9L Tech Talk Tech articles for the 03-07 Cummins Common Rail 5.9L Engines.
3rd Gen Tech: Icebox Intake
Old Dec 7, 2008 | 01:08 AM
wildcat's Avatar
Default 3rd Gen Tech: Icebox Intake
If you haven't considered this intake, PLEASE DO!!
I heard a little about it on the boards, and thought why not give it a try.
I ordered mine with the torque tube, and an Amsoil Ea nano Filter. The torque tube is shipped separately, BTW.
I installed it in my truck, only took about an Hour to do... Even with household interruptions...
I couldn't believe how easy the Icebox installed! The quality of fabrication was fantastic, and the kit contents were complete!
Here are some pics of the install.
After unpacking the Icebox, pardon the mess on the workbench...
Pic of the torque tube and Icebox.
The intake with the sensor installed.
Another shot of the installed sensor.
You need to remove the top cover next.
Disconnect the radiator overflow hose. Also disconnect the Negative lead of the battery
Remove the Stock Torque tube if you purchased an aftermarket unit.
You'll need to remove the Filter, to allow access to mount the Icebox to your truck.
The Icebox mounts to one of the fan shroud/radiator bolts. Remove this bolt, and compare it to the threads of the 2 included bolts. The CORRECT bolt is the one without the extra washer and self locking nut!
Just start bolt into threads of Radiator/fan shroud location.
Continued in the next post...
Old Dec 7, 2008 | 01:09 AM
wildcat's Avatar
Default Continued
Then align hole in back of Icebox to factory rubber mounted location, Place bolt through Icebox and factory grommet.. (This may require threading bolt through rubber grommet, as tolerances are tight.) Place washer and self locking nut on bottom and tighten until snug.
If you purchased a Torque tube with your Icebox, it's time to install it. NOTE: the long end goes to the Icebox, and the shorter end goes to the turbo.
(In this pic, the long end is to the Left, and the short end is to the Right...)
Pic of the tube installed... This is going to sound GREAT!! Note that clearance is tight to battery positive, and that Intake sensor is wrapped around outside of tube to keep it away from motor heat.
Reinstall the Air filter, I chose the Amsoil Ea nano filter option... If you use this filter, you'll have to "Persuade" it into position...
Reconnect the Radiator overflow.
Reinstall the top of the Icebox.
You are DONE! Don't forget to hook up the Negative battery lead, then fire it up and take it for a spin!!
Old Dec 14, 2008 | 07:33 PM
7.3 Cowboy's Avatar
That is cool. I like the step-by-step instructions.
Old Dec 14, 2008 | 07:48 PM
bobcat67's Avatar
Thanks Bill you da man glad to see you over here buddy
Old Jan 5, 2009 | 03:47 AM
wildcat's Avatar
I'm happy you guys like the article!
Old May 14, 2009 | 01:42 PM
jmiltier's Avatar
Nice looking product!
Old May 14, 2009 | 03:03 PM
txredman's Avatar
Texas Mafia
I would very highly recommend the ICEBOX!!
Old May 15, 2009 | 09:48 AM
icebox's Avatar
FormerVendor
Thanks guys!!! I need to get WILDCAT to rewrite all of my instructions!
Old May 15, 2009 | 10:35 AM
Johnny Z's Avatar
do they make them for 1996 12V 2nd gens? and how much? thanks!
Old May 15, 2009 | 10:48 AM
stkdram55's Avatar
yeah im like 99.999999% sure they do, they should be the same as for the 24v in the general aspect of it...PM icebox for a price he is currently online right now so you should get a answer back perty quick
