6.2L & 6.5L Performance Discussion of Chevy and GMC Trucks with 6.2L and 6.5L Diesel Engines Related to Performance and Longevity
Disappearing coolant
Old Nov 15, 2008 | 11:20 PM
junker46's Avatar
Default Disappearing coolant
Hi everyone.
My CUCV keep losing coolant and I don’t know where. It had some radiator issues a while back but didn’t seem too serious.
Here’s the rundown.
The radiator had a slight split seam a while back so slight I though it was a small pinhole. I kept running it but never got too low on water - it was a small leak and I kept the proper mixture on hand and kept it topped-off. Every now and then I’d get a low coolant light and I fill it up. Sometimes I noticed if using the heater after a while the heat quits and blows cold air: a sure sign of low coolant and do the same.
Then one day it blew and I limped the two miles back to the house. Pulled the radiator and had fixed. Replaces hoses and flushed the system. I never thought I overheated it because of no shutdowns or other heat related issues. However I have noticed since then if I’m driving it’ll lose an overflow reservoir of coolant every few days and get the no-heat heater bit again.
I have let it running fully serviced and warm but have seen no leaks or puddles underneath. There is no water/oil mixing signs and no steam or sweet smell coming from the tailpipe (as sometime you can see the billowing cloud and sweet smell from some car on the road). But I don’t know if there are other observable signs.
So I have:
  • Radiator trouble but fixed unit
  • Never thought it got too hot
  • Replaces hoses
  • Not seen obvious leaks, water-in-oil signs, or no steam clouds out of tail pipe
  • Have not replaced thermostat or radiator cap
  • And overflow tank (where I service it) runs out every few days.
Any ideas?
Old Nov 18, 2008 | 04:47 PM
biged681985's Avatar
if you had a cummins i would ask if you had the 53 block because mine would lose it and i could never find where till i finaly seen where the block had been half *** welded because of a crack in the block. but i dont know a hole lot about the 6.2l engines
Old Nov 20, 2008 | 07:55 AM
gunman41mag's Avatar
Moderator
Check your oil again, if no sign of radiator fluids, then I would change the radiator cap, it could be evaporating with-out you knowing !!!!
Old Nov 20, 2008 | 08:12 AM
wildbill's Avatar
Water pump could be leaking. How does the heater work when full of coolant and engine at full operating temp?? Blow hot, cold, hot, cold??
Old Nov 20, 2008 | 09:06 AM
Moderator
I once had a car that the heater was slowly leaking on the passenger side carpet, CHECK YOUR HEATER HOSE ????
Old Feb 11, 2010 | 08:46 PM
danielfoxracing's Avatar
i been though this a few times your heads are crack up in the chainrs and it will burn if lil so you dnt see it
duramax on fire
Chevy/GMC Duramax 01-04 LB7
11
Aug 14, 2017 09:51 PM
caissiel
Sep 24, 2015 05:37 PM
Rayrock4
Aug 30, 2015 09:45 PM
97f-250
Nov 23, 2014 08:08 PM
gmcmanis
Nov 9, 2014 04:49 PM
