Buddys truck problems
Old Nov 4, 2008 | 09:08 PM
bway1341's Avatar
Default Buddys truck problems
I replaced the IP and LP about 2 months ago. I was running it pretty hard!!! The truck started decreasing in speed check engine light came on and when I came to a stop sign it would not idle right kinda jump the rpm's up and down. This happened right as I got home and it was late, so i figuered I'd work on it the following day. It wont crank and smokes like hell while turning over. Its spits this sequnce out when I try for the codes: P ECU, P 1693, P Done, P Done, P ECU, P1690, P Done. Need some imput, Appreciate the help guys ....
__________________
2001 3500 cummins,,,, diablo power puck around 180,000 miles.
Old Nov 4, 2008 | 10:41 PM
94cummins12v's Avatar
"P ECU, P 1693, P Done, P Done, P ECU, P1690, P Done" well it looks self explanitory the truck is telling you whats wrong, your ECU is done just like it said. just kidding im sure someone can let you know whats going wrong this same thing happedend to my brothers truck 3 months ago i forgot what it was
Old Nov 4, 2008 | 11:05 PM
stkdram55's Avatar
all data says that the IP cam position sensor doesnt agree with the engine CKP sensor, most likely its the engine one thats bad if not the IP is bad i would change the engine crank position sensor its like $65 at autozone its behind the starter hopefully the oring on it isnt rusted or seized because mine was and it was a bonafide bitch to get out
Old Nov 4, 2008 | 11:34 PM
keithduke01's Avatar
not too bad to get out, just get a good ford tool! aka 4ft prybar!
if its got 188000 and you have never changed the ckp, then that is the most likely culprit, known to go bad, replaced 6 in the year that i worked at a private shop!
Last edited by keithduke01; Nov 4, 2008 at 11:34 PM. Reason: Automerged Doublepost
Old Nov 4, 2008 | 11:49 PM
stkdram55's Avatar
that will work but mine just kept breaking apart
Old Nov 5, 2008 | 12:14 AM
i talked to my brother and thats exactly what it was with his 24v
Old Nov 5, 2008 | 01:07 AM
stkdram55's Avatar
yep change that thing and be done with it
Old Dec 10, 2008 | 12:52 PM
wildbill's Avatar
Everything work out then?
Old Dec 16, 2008 | 08:58 AM
wildbill's Avatar
Any updates?
Old Dec 22, 2008 | 08:07 AM
wildbill's Avatar
Assume the issue has been resolved. Thread starter can reopen.
doublehbar
13
Aug 9, 2015 12:35 AM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Dec 3, 2014 09:40 AM
Oct 14, 2014 08:40 AM
