99 Dodge Ram 2500 4x4 ABS & Brake lights
Old Oct 23, 2008 | 03:59 PM
jeepdude's Avatar
Default 99 Dodge Ram 2500 4x4 ABS & Brake lights
I have a 99 Dodge Ram 4x4 2500 w/ cummins.
My ABS and brake lights come on when I push the brakes hard.
My speedometer works fine. Thanks for any help
Old Oct 23, 2008 | 08:14 PM
Woody35's Avatar
then wats wrong
Old Oct 23, 2008 | 08:23 PM
jeepdude's Avatar
Default RE
I sorry I didn't explain good enough.
The amber ABS light and the red BRAKE warning light in the instrument panel come on and stay on when you push the brake pedal hard. They go back off when you shut off the truck but come right back on when you push the pedal hard again. thanks
Old Oct 23, 2008 | 09:34 PM
Nitelord's Avatar
Is it still drivable?
I had those symptoms, but my problem was a blown brake line at the right front caliper.
I was blowing brake fluid all over the place. If your not loosing fluid, My (guess) is electronics.
Sorry I can't be of more help, I'm no expert, just go from experience is all.. Good luck..
Old Oct 24, 2008 | 12:23 AM
Theres a possibility that you have a collapsed brake hose. If thats the case, you will usually find a stuck caliper.
Notice any funny braking?
Old Oct 24, 2008 | 05:30 AM
jeepdude's Avatar
Brakes work fine and I drive it every day.
Old Oct 26, 2008 | 01:23 AM
ABS sensor ????
Any codes set?
Old Oct 26, 2008 | 12:12 PM
jeepdude's Avatar
I tried the rear differential abs sensor and it didn't help.
I'm not sure how to get the codes without going to the dealer?
It doesn't have front Abs sensors.
Old Oct 26, 2008 | 12:44 PM
You should be able to go to Autozone and use their scanner if you dont have one. You should think about getting an OBDII scanner for yourself.
Old Oct 31, 2008 | 04:19 PM
jeepdude's Avatar
Default Fixed
My rear brake auto adjusters were froze up not allowing adjusters to work and the rear brake cylinders were stroking too far causing the lights to come on.
Turbo67
Jul 25, 2015 02:26 PM
river rat
May 18, 2015 05:04 PM
hoeky22
For Sale
Mar 15, 2015 08:35 PM
Dec 29, 2014 10:20 AM
Oct 24, 2014 02:50 PM
