ENGINE SWAP
Old Oct 17, 2008 | 03:54 PM
OLD SMOKEY's Avatar
Default ENGINE SWAP
First time poster: Looking for advice on swapping out 1996 dodge ram v10 engine with a 1996 cumnings diesel 5.9. I have the diesel complete donor truck (heavily damaged front end) . Have my eyes on a 1996 v10 extended cab 4x4 and require details on swapping out engine and tranny and ??? . Trucks are same year.
Thanks in advance Old Smokey
Old Oct 17, 2008 | 10:16 PM
lilfroger's Avatar
Should be a fun time. Heck of a lot easier than the one we are doing. Took the V10 out of a 96 and shoving a 92 12v into it. Most of the hang-up's we've run into were caused by the 12v. So it shouldn't be that bad.
The motor mounts should line up between the block and the frame.
You will have to wire up a heater grid light.
Good luck and keep us updated
Old Oct 18, 2008 | 07:23 AM
BigDiesel359's Avatar
Also remember fuel lines and tank will have to be switched over, new or flushed out well.
Old Oct 28, 2008 | 02:08 PM
JakeDeisel's Avatar
Pretty common swap to do. You can get away with just flushing your tank out, or swaping the other tank over would be easier and a lot cheaper. good luck.
burndiesel
10
Feb 7, 2023 01:15 AM
boylesjesse
Apr 8, 2015 10:11 PM
DetroitDiesel
Jan 29, 2015 08:13 AM
metal_miner
Dec 23, 2014 11:40 PM
Lee Chisholm
Dec 3, 2014 05:58 PM
