Big Rigs & Semis Discussion of Diesels Used for Transportation of Goods
N14 Cummins Are No Fun.......
Old Oct 8, 2008 | 07:22 PM
LOGANSTANFORTH's Avatar
Default N14 Cummins Are No Fun.......
when G.I Joe runs them completely out of oil and it spins THEN welds the number 5 main bearing to the crank and you cant turn the motor over to get the centrifigul clutch bolts out.........still got to check the number 7 bearing........then you got to take a hammer, chisel, and cut off wheel to get some of it off and its still stuck........
Old Oct 8, 2008 | 08:21 PM
Racer9's Avatar
Just pull the pan, or cut a hole in it, and cut the crank in two. You'll be able to spin the flywheel, and the crank is already junk.
Old Oct 9, 2008 | 03:47 AM
easier said than done........pans off all but the front main and rod caps are off but i really dont want to lay under that SOB with a torch cutting through 3.5 inches of crank journal.......we are just pulling the 16 speed caterpillar automatic out of it now so we dont have to mess with it.......its getting a new engine either way so it dosent matter.......
Old Oct 11, 2008 | 10:43 PM
nevrenufhp's Avatar
The most I could do as a 63B was replace a head gasket on a Deuce. Wish I would've known how to crank up the power on em back then. Your shop gets all the fun!
Old Oct 12, 2008 | 03:14 AM
NO we get all the junk GI Joe destroys cause of lack of maintenance.........this is an OLD M920 6 wheel drive semi truck......
Old Oct 12, 2008 | 10:18 AM
nevrenufhp's Avatar
We had quite a few of those old skool 900s, and very few of the A2s(with the 6CT). They sound really mean when str8 piped!
The Deuce headgasket was from our own mechanic. We were having a class in recovery, and he put it in reverse instead of 1st, and sunk it in a pond....at the end of class of course. 3rd CAV!, I got out in 94.
Old Oct 22, 2008 | 10:38 PM
jmono33's Avatar
Sounds like a PITA! Makes me think twice about going to school to work on them...
Just kidding...
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
Dec 18, 2014 03:25 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
