Missing, Low Oil Pressure Instantly!
Old Sep 30, 2008 | 04:00 PM
JPMS's Avatar
Default Missing, Low Oil Pressure Instantly!
Ok I hope by via the internet someone out there can help me.
I have talked to many mechanics my area and they all must be part installers because I get a different list of parts to replace in an order when each one doesnt fix the problem.
The truck ran fine, turned off, started and died, no start after that and the oil gauge never moves. It had a code P1212 so I started by installing a pressure gauge in the pressure switch on top of the resevor. No pressure, installed a pressure gauge at the plug above the oil filter, no pressure, turned the engine over and oil will slowly run out the plug hole at the filter but it doesnt fill the HP resevor.
So I am here, no start and no low pressure oil. What is causing this issue to happen instantly?
99' F450 4x4, 7.3 Intercooled, Manual trans, built date of 10/99 136,412miles.
Help me if you can, that truck is my way of life, no food on the table when it doenst run.
Old Sep 30, 2008 | 05:05 PM
wildbill's Avatar
Failed oil pump is all I can guess.
Old Sep 30, 2008 | 08:42 PM
MRaynor's Avatar
X2
Old Sep 30, 2008 | 09:36 PM
idismoker91's Avatar
pretty sure they are right
Old Sep 30, 2008 | 09:45 PM
wildbill's Avatar
Are they gear driven or do they run off a shaft like the 6.2L GM diesels? If it's run off a shaft, look for a broken one.
Old Oct 1, 2008 | 07:02 PM
hey i was talkin to a couple guys i work wiyh and my dad who works on powerstrokes all day and they all said it was a bad oil pump from wat you said
Old Oct 7, 2008 | 11:48 PM
I assume this is under control now.
robbyS
Apr 16, 2015 02:22 PM
jhprice
Mar 29, 2015 09:36 PM
Ruddedawg5.9
Mar 1, 2015 09:16 PM
powerstroke4178
Nov 27, 2014 02:35 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
