LB7 intake box mod
Old Aug 30, 2008 | 12:12 AM
2500HeavyDuty's Avatar
Default LB7 intake box mod
To take off the stock air box loosen the two hose clamps on the intake tube on each end. a 5/16 or flat head screw driver would work fine.
Disconnect the MAF sensor ontop of the airbox and yank on the box upwards to remove it, its pressed in to fit there no bolts holding the box down. Once you have it out you can start cutting it up to let the air flow a little easier.
Heres some pics of my modded air box on my 01 duramax.
I took a grinder wheel and started to make swiss cheese out of my stock air box. I cut two sections out the front of the box so the air can ram in from behind the light.
and i got a little carried away and went ahead and removed the old intake slots that go to the fender:
Overall this is how it looks.
Old Aug 30, 2008 | 12:20 AM
Oilfield_Mafia's Avatar
Nice Writeup Dano! The LB7 Box looks alot different than the LBZ box from these pictures..
Old Aug 30, 2008 | 12:36 AM
sure does, I don't think you absolutely need the two holes on the front, just the big one cut out should be enough for the air to move in. the things on the fender side can be left alone, but this is what i did.
Old Aug 30, 2008 | 03:09 AM
DangerousDuramax's Avatar
Actually do NOT remove the slots going to the fender. This aids in flow direction and CFM. The LBZ system is what Txchristopher designed and GM stole since he didnt patent it so you can thank him for the lowered IAT and EGT's.
Old Aug 30, 2008 | 07:29 AM
bigdaddydiesel's Avatar
Nice!
Old Aug 30, 2008 | 10:08 AM
yep u knew i cut out a bit too much, oh well works for me
Old Aug 30, 2008 | 04:19 PM
Diesel-N-Dust's Avatar
Good write up Danny
Old Oct 6, 2008 | 08:52 PM
WyoD-MAX's Avatar
did you notice a big difference with the modded box?
Old Oct 6, 2008 | 11:16 PM
compared to my afe stage 2, i feel like i have more top end with the stock modded box
Old Feb 2, 2009 | 06:34 PM
03maxpower's Avatar
what filter are you running with that danny?
