PPE Boost Increase Valve Install Guide
Old Aug 27, 2008 | 04:05 PM
bigdaddydiesel's Avatar
do you buy all this stuff on a regular basis???
Old Aug 27, 2008 | 11:14 PM
2500HeavyDuty's Avatar
i know some tricks that can make something like this just a little bit better
Old Aug 11, 2010 | 09:34 PM
RIDEN' DIRTY d-max's Avatar
is this product worth it iv been thinking about getting it for a while...some people i talk to say it helped them out some people say it didn't do anything for them
Old Aug 11, 2010 | 10:38 PM
Red_Rattler's Avatar
High Tech Redneck
26 bucks might be worth a shot if you gain about 10 psi from it...
Amazon.com: PPE Boost Increase Valve for 01-04 Duramax 6.6L LB7: Automotive Amazon.com: PPE Boost Increase Valve for 01-04 Duramax 6.6L LB7: Automotive
Old Aug 11, 2010 | 11:05 PM
captain_stabbin's Avatar
how does this increase boost? is it restrictive?
Old Aug 11, 2010 | 11:10 PM
High Tech Redneck
pretty much, its a "boost elbow" for a dmax
Old Aug 12, 2010 | 02:23 PM
the boost valve has two orfices in it, one to let air go to the wastegate very slowly, and the other to vent off that air trying to get to the wastegate. theyre pin holes basically
Old Nov 3, 2010 | 02:05 PM
CumminStrokeThisDuramax's Avatar
So do you think putting the boose valve and running a programmer on an 01 duramax with a stock tranny will be to much? I currently run it at a 165 hp stage and it runs fine with no sign of slippage (of course i'm not in it all the time).
Old Nov 3, 2010 | 04:14 PM
i limped my trans with just a 135 tune and no valve on it.
Old Nov 4, 2010 | 08:21 AM
How many times have you limped it? I've only limped mine once in the 6 months that i've ran the programmer at the 165 hp tune and ever since that time I haven't limped it since. I'm just curious if you think that it'll be a bad idea to put the boost valve on my truck but turn the tuner down to maybe the 110 hp tune. The reason being that i want the vavle is due to my wastegate being wide open so the slightest amount of boost being built the wastegate kicks in and releases the air>
