Meth/Water Injection Anyone ?
Old Jul 5, 2008 | 11:36 PM
Default Meth/Water Injection Anyone ?
how much of a performance boost? will boost numbers rise over 35psi?
Old Jul 6, 2008 | 11:07 AM
sidekick's Avatar
not sure but looking at snow performance to cool mine down
Old Jul 6, 2008 | 11:27 AM
rubberfish's Avatar
I have a stage two Snow kit. No regrets at all.
I don't see anything off the pyro, but the dyno does
show an extra 60rwhp with a 50/50 mix.
Old Jul 9, 2008 | 04:04 PM
GO OVRIT's Avatar
With a 50/50 mix, you won't see any drop in egt. To use it to cool things down you have to use more water and less meth. You gonna set your up Sidekick?
Old Jul 9, 2008 | 06:57 PM
sidekick's Avatar
thinking about it 1600+ degrees is to hot to me but hay the famous words I DONT CARE ITS UNDER WARRENTY
Old Jul 9, 2008 | 07:11 PM
2500HeavyDuty's Avatar
if you got the stock turbo and waste gate it shouldn't go over 35 psi at all, even 30 its hard to pull off with the waste gate controlling your boost.
Where do you plan on adding the water meth at?
Old Jul 9, 2008 | 09:55 PM
Snow Performance
Old Jul 10, 2008 | 12:06 AM
Begle1's Avatar
Cooling Mist computer-controlled DMS plus gadgets off of eBay; more effective than anything else at fractions of the cost.
http://www.1stgen.org/viewtopic.php?t=2700
A Snow kit can cost $800. I can get a 4000 watt inverter for $150, a 1 GPM @ 1000 PSI electric power washer for $150, a nitrous solenoid for $150, a boost pressure transducer for $100, a 1000 PSI diffuser nozzle for $40 and a Cooling Mist programmer for $200.
Old Aug 27, 2008 | 02:50 PM
bigdaddydiesel's Avatar
Default BANKS
Will a Banks Wastegate make a diff???
If so how much???
dwmeehan
Jan 29, 2025 12:13 PM
Cougdiesel
Feb 2, 2016 10:17 AM
1997silverado
Sep 11, 2015 11:27 PM
letters4and18
Dec 11, 2014 12:03 PM
rtbcoop
Nov 29, 2014 11:33 PM
