Limp Mode, No Tach...Wiring?
Old Mar 19, 2026 | 08:54 PM
Shesgonnablow!'s Avatar
Question Limp Mode, No Tach...Wiring?
Well, I fired up my 1997 one-ton dually service truck this afternoon, warmed up the cummins diesel and backed up. So far, so good.
But when I put it in Drive, it really struggled to get going up a slight grade. I realized it WASN'T in first gear!
Getting it on the road, I thought the tranny might just need to warm up or something. But it continued being locked into 2nd gear.
Strangely, the Tachometer also crapped out on me. I could hear my 5.9L cummins revving up about 2000 to 2250 or so, but the tach said 0.
Even stranger: both the tranny and the tach came back to life somewhere while I was driving!
I would've chalked that up to Gremlins or some other devil and gotten on with my life. But it happened again and continues to operate in 2nd with no tach.
So far, I've found out that the tach works off a Crankshaft Position Sensor aka Engine Speed Sensor (ESS) and that gadget uses a 5VDC supply (from the Engine Computer?) using 3 wires. And apparently I'm in "Limp Mode" now, stuck in 2nd gear.
Is it possible that these 2 phenomena are related? If that sensor went out, would it kill the tach and ALSO put me in Limp Mode?
Unfortunately, my rig got stolen a couple years ago and they must've only watche the GTA movies, cause they sure didn't know how to PROPERLY hotwire a vehicle. Caused an ENGINE FIRE that burned up the main wiring harness. About $5K later, and 40 solder-splices I had to do myself, I got it running again (though I lost the Speed Control). No problems till now. Maybe one of those solder connections - like going to the ESS - went bad?
Thanks so much for your help!
Old Mar 23, 2026 | 12:29 AM
steven shi's Avatar
Cummins Tech Tip: 🛠️ Tachometer at 0 + Transmission stuck in 2nd Gear = ESS (Engine Speed Sensor) Failure. > Without the RPM signal, your PCM triggers "Limp Mode." Check your ESS gap (.050") or your previous harness solder joints for high resistance.
Old Mar 23, 2026 | 02:13 AM
Default Limp, No Tach but wiring seems ok?
Found the ESS (Engine Speed Sensor) and traced the wiring using this diagram. Colors matched up and there was a 3-wire connector about a foot up from the sensor, so I unplugged it.
Tested for Hot or Ground on all 3 contacts with engine OFF. All 3 showed continuity to Ground.
Tested with Ignition in ON position: The Hot contact (5VDC) was indeed Hot; the Ground contact was Grounded; nothing on the Signal contact, so...
Traced the Signal wire using a Telecom tester (Signal Generator and Probe) and it traced right back to the PCM, like it's supposed to.
So. Wiring SEEMS
ok! Then what in the world is going on?
ferrari90quad
Jul 1, 2013 08:15 PM
JRHoward
Jan 6, 2013 04:40 PM
jake0789
9
Feb 2, 2012 05:14 PM
caylebk
10
Feb 28, 2011 11:10 PM
CommonArcWelder
11
Jan 19, 2009 01:28 AM
