V2203 to AX15 adapter
Old Nov 3, 2022 | 06:46 PM
cj6's Avatar
cj6
Default V2203 to AX15 adapter
I'm hoping someone out there in the forum has some sort of CAD design to marry a Kubota V2203 to an Ax15/NV3550. I have a friend that can cut it out for me for the cost of material, but I don't have a good template to work with, nor do I have the transmission yet.
Any help out there? I'm mechanical, but not much of a fabricator, and being able to hand of a file would make my life a whole lot easier.
Old Jan 2, 2023 | 05:48 PM
Duallyjeepster's Avatar
Try Phoenix Casting and Machining in Juniata Nebraska. We are doing the same V2203 to AX15. Need to make sure you have a standard depth SAE 4 flywheel housing and SAE10 flywheel.
Old Jan 4, 2023 | 08:33 PM
cj6's Avatar
cj6
Thanks for the info. Curious as to the SAE 10 flywheel. Are you not using the Ax15 flywheel? What about the clutch? I know Kubota swappers uses the original flywheel and clutch, but they've paused production.
Old Jan 4, 2023 | 08:54 PM
They sell an adaptor that goes between the SAE4 flywheel housing and the clutch housing and an adapter between the SAE10 flywheel to the clutch. You do not need the original jeep flywheel. The might sell adaptors to do different set ups, you would just have to call and ask. They’re very knowledgeable people.
Old May 11, 2023 | 04:36 AM
MeganCates's Avatar
Thanks for the advice.
turbo6bar
61
Jul 31, 2019 04:39 PM
C12H23
Wanted To Buy (WTB) - Used
Oct 13, 2016 10:57 AM
rebel s10
Jul 13, 2014 10:16 PM
JesterGrin_1
Jun 10, 2014 03:14 PM
JesterGrin_1
Jul 6, 2013 11:32 PM
