Hard / No start issue with code p1012
Old Jun 7, 2021 | 12:01 AM
Scohee82ram's Avatar
Default Hard / No start issue with code p1012
107.5 ram 3500 6.7L 6spd 141,000mi I can crank all day long it will not start but with a little shot of ether it will start and run, bit it gives me a P1012 code, fuel pump delivery pressure too high Anyone have any ideas of what is wrong with it I've replaced the fuel rail pressure sensor and also the fuel pressure regulator on the back of the CP3 pump, and it is still giving me the same issue
Old Jun 7, 2021 | 12:18 PM
107.5 ram 3500 6.7L 6spd 141,000mi I can crank all day long it will not start but with a little shot of ether it will start and run, but it gives me a P1012 code, fuel pump delivery pressure too high, figure out how to watch my live data on my handheld scan tool last night, its making 20 psi while cranking if I use a little either and start it it's making 9,000 to 13000 PSI at idle and goes up if I hit the throttle, I have replaced the fuel pressure sensor and the fuel pressure regulator on Back of the CP3, anybody have any idea on what's going on?
Whitman41
Aug 19, 2014 04:53 AM
Julsonjr
May 20, 2014 01:07 PM
WyattsRam
Feb 27, 2013 05:26 PM
gribble21
Mar 11, 2012 05:51 PM
tang8u
Feb 23, 2011 09:31 PM
