P0234 code
Old Dec 8, 2020 | 11:46 AM
Nobleman's Avatar
Default P0234 code
04 chevy duramax lly, With codes cleared when starting throws code P0234. When driving, goes into limp mode, when it shift into 5th gear. Throws code P0700 and P2227. P0234 says overboost. The boost pressure is 27.5 psi (according to the snap on scanner) at idle. Hits between 36 and 39 psi then goes into limp mode. Replaced vane position sensor, still does the same thing. Looking for info what to check next.
chadcycle 2500
5.9L 24V Performance
Oct 8, 2015 04:34 AM
geareater
Chevy/GMC Duramax 06-07 LBZ
Apr 21, 2014 07:48 AM
RINEHOLT98
Nov 7, 2011 08:49 PM
DuramaxMann
9
Feb 3, 2011 03:10 AM
wrightfamily07
Oct 6, 2008 07:50 PM
