Intermittent hard shift dt. P0500 1996 7.3 powerstroke
Old May 9, 2020 | 04:47 PM
bigjohn1982's Avatar
Default Intermittent hard shift dt. P0500 1996 7.3 powerstroke
I have a frame off restoration f250 its stock except for a cold air intake and a 4 inch turbo back exhaust and a 3 inch lift for clearance of exhaust, it has a brand new jasper rear end , problem started with abs light constant and hard shifting took to a trans shop and they pulled the p0500 code and said the transmission is fine , I have put another vss sensor in checked wires from there to psom even though the speedo works as it should , checked wires from. Psom to pcm plug with less then .5 ohms of resistance, checked all fuses , and at this point I. Lost and this is my only transportation
The Diesel Tech
Jan 21, 2017 12:30 AM
mike211
Jan 24, 2016 09:05 PM
BigRigButters
Aug 12, 2012 08:43 PM
ALWAYSREADYROB
Mar 4, 2012 04:55 PM
powerstroke9773
14
Sep 2, 2011 06:44 PM
