2004.5 5.9 Cummins throttle issue
Old Jan 6, 2020 | 12:03 PM
Powell556's Avatar
Default 2004.5 5.9 Cummins throttle issue
Have an 04.5 3500 runs good until about 2krpms and then has no more throttle. Truck isn’t throwing codes.
Old Jan 8, 2020 | 07:34 PM
Bigg Redd's Avatar
Sounds like it may be an issue with the Accel Pedal Position Sensor (APPS). This is part of the pedal assembly. If in fact this is the issue, the entire pedal assembly would have to be replaced.
Old Jan 9, 2020 | 01:51 PM
Powell556's Avatar
Is there a way I can test this?
Old Jan 9, 2020 | 06:03 PM
mikmaze's Avatar
tps could be in one of three locations on a 04.5, at peddle, right above cp3, or a thrid that I forget...........
Old Jan 25, 2020 | 11:30 PM
Cp3's Avatar
Cp3
Is it auto? It could be under the intake horn, or the batteries boxes, I suggest you get a Jimbo's throttle positioning sensor from Geno's garage.
​​​​​If you get it, it will only work for trucks with the sensor mounted under the intake horn, I think.
Make sure you set it as the instructions say, otherwise you'll end up with like 1/8 of pedal movement with no response. Commonly known as dead pedal.
Buzzzard16
Chevy/GMC Duramax 06-07 LBZ
Aug 12, 2017 12:36 PM
2.S.F.L
May 3, 2010 01:07 AM
02 cummins
Dec 28, 2009 11:03 AM
cowbum
12
Jan 23, 2009 08:28 AM
RJ818
25
Jun 26, 2008 11:50 PM
