Will Removing Cat Throw Codes?
Old Jun 20, 2008 | 12:14 PM
Seadrivejoe's Avatar
Default Will Removing Cat Throw Codes?
I have an '03 LB7 and am looking at systems to remove the converter but have heard that removing the cat converter will cause the engine to throw codes. Any truth in that and how do you overcome?
Thanks, Joe
Old Jun 20, 2008 | 01:51 PM
Oilfield_Mafia's Avatar
Hey Joe, mine is an 07 lbz and I just put a turbo back MBRP on and got an insignificant code. I think its a hit or miss type deal. There are several programmers that will block the EGR code that comes up and you can also use a finger stick to block the code as well. So u have multiple options. Hope that helped ya.
Old Jun 20, 2008 | 03:31 PM
jdugie123's Avatar
ya it is hit or miss it may thru a CEL it not. mine never did but i did thru codes just never showed on the cluster so it may or it may not. if it does you can get a finger stick and that will take care of it
Old Jun 20, 2008 | 09:26 PM
redneckbuckeye's Avatar
I think you will have no code on the LB7 for removing the cat. I could be wrong but I was thinking the only LB7 that had a Cat was the California emissions equipped trucks.
Old Jun 20, 2008 | 09:46 PM
TCU Fan's Avatar
Aaron
I guess it depends, I had an LB7 and it was made without a CC.
Old Jun 23, 2008 | 05:55 PM
2500HeavyDuty's Avatar
No cat on mine, no code. but it came stock with no cat
longhorn12
6.7L Performance
Aug 29, 2015 01:28 PM
willyam
Price Quote - Request A Price
May 19, 2015 10:20 AM
Renowest48
Dec 14, 2014 08:36 PM
jmerriman17
Nov 21, 2014 04:38 PM
Altonlee
9
Oct 8, 2014 02:31 PM
