Hard start
Old Apr 3, 2019 | 12:45 AM
mopwr2004a's Avatar
Default Hard start
Have a intermittent starting problem.
First crank up of the day it starts first hit of the key.
Drive some then the problem starts.
Have to crank the engine over alot for it to start. This doesn't happen all the time. I may drive it several days with no issues.
The trk is a 07 w/5.9 - 6spd
Old Apr 3, 2019 | 11:54 AM
11B/11C's Avatar
When it cranks but doesn't start, what's your cranking RP?
Old Apr 3, 2019 | 09:02 PM
mopwr2004a's Avatar
Default Engine spins fine, just struggles to fire off
Turns over like supposed to. Not turning over slowly
Old Apr 3, 2019 | 10:27 PM
Bigg Redd's Avatar
Mine had similar issue about 3 yrs ago. turned out to be FCA (fuel control actuator). no issues since. Any code(s)??
Old Apr 4, 2019 | 07:52 AM
mopwr2004a's Avatar
No codes at all, where is this part located your talking about.
I was thinking lift pump or something of that nature
Old Apr 4, 2019 | 08:28 AM
Bigg Redd's Avatar
The FCA is located right at the injection pump. Its held on by 2 small bolts, and has a wire connector attached. If your truck fails to start, disconnect the connector and try to start it. If it starts, then the FCA is faulty, however don't run the engine for more than a few seconds.
doublehbar
Oct 23, 2019 01:48 PM
MrSandman818
Feb 6, 2012 06:56 PM
98dodgecummins
Oct 31, 2010 05:50 PM
1slow24
17
Jul 19, 2010 07:59 AM
cumminsCrazy
May 10, 2010 10:09 AM
