Turbo Noise?
Old Nov 17, 2018 | 10:39 AM
caleb_secrist's Avatar
Default Turbo Noise?
Alright so ive heard a similar noise like this before and it turned out being the turbo bolts loose, wasn't that this time. I replaced the gaskets today because they were shot and still no fix. its a 62/65/14 from smeding over a 75mm. Im leaning towards turbo bearings even though the center section has less than 2k on it. It sounds like a squeal noise, best I can describe. Noise is dependent on drive pressure though not boost pressure. Steady 20psi no noise but 20psi up a hill throttle down I hear it. I can send texts of the noise just don't know how or if I can post video here. Thanks guys
Old Nov 29, 2018 | 03:59 AM
Crawler's Avatar
Check the end play and side to side play on the turbos. If that checks out then I’d start looking very closely at all the gaskets and the charge air system for a leak.
If if you still can’t isolate it then even if the shaft play checks it could be a bearing.
Look ok at the housings and wheels very closely. If they are rubbing, you should be able to tell.
Old Nov 29, 2018 | 12:57 PM
I called my guy at smedding and he said if the shaft is tight it more than likely an air leak. Ill have to look at it when I get a chance. He said check manifold with it being stock. Will take a smoke machine to it. Ill let you guys know what it is.
Old Dec 2, 2018 | 12:54 AM
Crawler's Avatar
What did you find?
Old Dec 3, 2018 | 08:53 PM
Bigg Redd's Avatar
When in doubt, throw it out.....
OR rebuild that badboy. You certainly do not want to ingest ANY metal particles or shavings into your engine. A replacement or properly rebuilt turbo is cheap insurance against total turbo failure leading to severe or total engine damage.
Old Mar 27, 2019 | 01:55 PM
Sorry for late response. Turbo was fine. I ended up swapping manifolds to a 3pc. Shouldve done awhile ago. noise went away. was either bad gaskets or crack in manifold to those having same issues.
Old Mar 28, 2019 | 07:00 PM
Bigg Redd's Avatar
Nice job! Glad to hear it.
Billy D
16
Dec 4, 2011 09:03 PM
langleymetalworks
Chevy/GMC Duramax 06-07 LBZ
Jun 26, 2011 01:30 PM
smokedout
10
Feb 12, 2011 09:04 PM
bjennen
Dec 13, 2010 10:31 AM
jake 94
8
Jan 16, 2010 09:10 AM
