exciter wire to the alt no power need help pls
Old Oct 31, 2018 | 11:12 PM
chevy6.537's Avatar
Sad exciter wire to the alt no power need help pls
so i changed my alternator because the old one wasnt charging the battery and even with the new one still the same thing so i check the fusible link with a voltmeter is good and as well the exciter wire goes to the alt should have 12volt when the key is on but nothing !!the ecu control the voltage going to the alt ? and also when the key on the dash battery light dont come on so pls need help
Old Dec 26, 2018 | 10:20 PM
monarog's Avatar
Check the fuse, located above your left foot, while in the drivers seat. Happened to me, and the Battery Isolator was bad, causing the fuse to blow. You will need to look close, this fuse is shared with a lot of other things, but is labeled Alternator, along with a host of other things.
Gear
Nov 24, 2017 01:03 AM
austin j.
Jan 31, 2013 08:33 AM
logdrum
Dec 17, 2012 09:05 PM
Baradium
Jun 17, 2012 12:21 AM
Mudbug
May 5, 2010 12:31 AM
