Fuel Pressure too high... Engine dies
Old Oct 7, 2018 | 10:22 PM
Desert Fox's Avatar
Default Fuel Pressure too high... Engine dies
My 2000 5.9 4x4 is approaching 220,000 miles and has been fairly faithful. I had replace the VP44, and then upgraded my lift pump when my fuel pressure gauge indicated the old pump the PO put on was dying. I replaced a Universal style pump with a FASS DDRP. All was well, until one day as Im leaving my house the truck stumbles and dies. I check the grounds for some reason, hop back in and she start back up. This happens sporadically, until i realize that when i start it, sometimes the fuel pressure pegs the gauge out at 30 PSI, and shortly after that the truck dies.
It finally left me stranded, and I parked the truck, driving it much less. I had "fixed" the problem several ways including tapping on the DDRP, Opening and closing the drain valve on the fueld filter housing, and making sure my battery cables were tight.
After endless googling, I have no idea what is causing the problem. I cant readily replicate it. Im not even sure if my "Fixes" are doing anything. I really want to get this thing back into tip top shape and throw a few grand at it to get it bulletproof for at least another 50K.
Any Ideas?
Old Oct 8, 2018 | 10:43 PM
Crawler's Avatar
First things first-Adjust the fuel pressure on the FASS down to 15psi.
Then give us an update and we"ll give you a more comprehensive list to chase down.
Old Oct 10, 2018 | 10:51 PM
Desert Fox's Avatar
Crawler,
the lift pump is a FASS DDRP, I do not believe it has fuel pressure adjustments like the bigger better models. I believe it is just a spring regulator in the pump housing. This is why I tapped on the pump hoping to maybe unstick a spring that was stuck?
Old Nov 18, 2018 | 12:34 AM
doublehbar's Avatar
I do believe the DDRP is adjustable. I don't recommend manually adjusting the fuel pressure on the pump until you get a reason on why this is happening to your fuel pressure in the first place. Have you called FASS tech support? They are great to work with!
doublehbar
17
Feb 13, 2016 11:52 AM
roadglide
Nov 23, 2015 04:35 AM
Devon527
May 2, 2014 12:27 PM
jdcanvas
Chevy/GMC Duramax 01-04 LB7
Jan 24, 2011 02:05 PM
98dodgecummins
5.9L 24V Performance
49
Aug 7, 2010 10:42 PM
