6.6 Brazilian swap
Old Sep 30, 2018 | 09:27 PM
thumper_65590's Avatar
Default 6.6 Brazilian swap
Hey all, new here and thought I would share my latest swap. I didn't do most of the swap, just gotta finish it up. It is a 95 F350 with a 6.6 Brazilian, has the 545 Allisn that was behind it in the donor vehicle behind it, as well as an auxillary divorced overdrive. As far as the engine, all I have to do is replace the voltage regulator and rout my air cleaner and exhaust. Driveline is somewhat of another issue. I have a vibration at almost all speeds, but is really pronounced at anything above about 40MPH. I believe it is coming from the final driveshaft. It is very short, and I believe it may have too much angle and is binding up some. I am going to try to get a spirit level and check angles and phasing this week. I do have a few questions though. I would like to add a little more boost to her. Does anyone have any idea how large of a turbo I could add? I am going to check the pump and see how hard it would be to turn it up a little. Anyway, here are some pictures of the Green Goblin
Attached Thumbnails 6.6 Brazilian swap-00s0s_1oiebppqnqf_600x450.jpg   6.6 Brazilian swap-00t0t_koiksphexva_600x450.jpg   6.6 Brazilian swap-00v0v_ki8cq3f6re_600x450.jpg   6.6 Brazilian swap-00w0w_1kteepz0btr_600x450.jpg   6.6 Brazilian swap-00w0w_gwujwbglirk_600x450.jpg
Old Oct 5, 2018 | 01:59 PM
u2slow's Avatar
From what I know of those engines, they are loosely a mirror-image of a 6BT with a Bosch inline pump similar to a p-pump. Should not be too difficult to squeeze more jam out of it. What turbo is on it now? Maybe a Holset from a 6BT can be swapped....
I think the auto trans (non-lockup; direct) and aux OD will be less than ideal in the long run. I like an auto for a yard tug, but otherwise I prefer manual shift on the road.
Old Oct 16, 2018 | 09:35 AM
2wpuller's Avatar
That tq.converter is usually a little loose.What OD trans do you have? I have a Allison 1000 out of a 06 Chevy 6 sp.Using a standalone electronics I made.Programming done with EFI.
Old May 27, 2020 | 05:30 PM
2wpuller's Avatar
Have you figured out your vibration?
I had a 5831 Spicer 3 speed behind a MT40 allison 6 that had lockup but no overdrive. The Spicer was a under direct, overdrive, .Don't remember exactly think it was 10% of
Your swap is interesting haven't seen anyone else doing it.
John Dwight
19
Jan 6, 2022 01:52 PM
Jgloveracob
Nov 16, 2014 07:27 AM
KillStroker
9
Mar 12, 2011 10:30 PM
Thumper
6.0L Performance
Oct 15, 2009 05:42 PM
connermcpherson
Feb 25, 2009 09:19 PM
