no power
Old Jul 26, 2018 | 07:13 PM
Thomas N. Moss's Avatar
Default no power
have a 2006 5.9 and I have code that will not delete. Autozone print out states P1740,P0238, P0237, P0236 and P013. It says to replace fuel pump. So 3 of them are MAP sensor voltage. I have a MAP fooler in and do not know what to do next.
Help please
Old Jul 26, 2018 | 11:52 PM
Crawler's Avatar
Was the map fooler installed prior to the codes or are you trying to use it as a part of the diagnostics?
If it was installed at the time the codes occurred, then take the map fooler out of the equation. Clear codes and see what codes return.
Without looking up codes, I believe P1740 is a transmission solenoid code. Torque converter solenoid. I think.
P013 doesn't sound correct, can you verify?
P0236, P0237, P0238 are MAP codes
What all is done to the truck that is not factory?
hiusmell
Oct 29, 2013 01:22 PM
Echo driver
Aug 24, 2013 07:01 AM
duckslayer31
Jan 7, 2013 12:23 AM
Texas Rocket
Chevy/GMC Duramax 06-07 LBZ
8
Mar 11, 2009 10:07 AM
dalton06
5.9L CR Performance
27
Jun 15, 2008 08:44 AM
