2006 5.9 cummins white smoke at idle on startup when warm
Old Jul 15, 2018 | 09:07 PM
Joshplee's Avatar
Default 2006 5.9 cummins white smoke at idle on startup when warm
i have a 2006 5.9 cummins with 218000 miles on it, im not the original owner so im not sure what work has previouly been done to it, but here are the symptoms. When i start it in the morning ( even when its 70 degrees), it has a little white smoke and a slight miss for the first 3-5 min, then it clears up. It always starts quick and has good power. I did an injector kill test and when its cold the number 1 cylinder only had a very slight difference in sound, unlike cylinder 2-6, after the truck is warm, number 1 kill test seems normal. Also, when cold and the kill test is done on number 1 the white smoke immediatley disappears. I thought maybe i had a bad injector on the number 1 cylinder so i switched number 1 and number 2 injector. I did the kill test again while cold and got the same exact results and the white smoke stayed with cylinder number 1. I did a cylinder contribution test and results 1-6 were the following 99, 102, 107, 97, 98, 106. Coolant and oil levels seems to be normal. What do you think the issue could be, ( FCA, injectors, rings, pistons)? I do have some blow by, but does not seem to be using oil.
Old Jul 18, 2018 | 02:41 PM
11B/11C's Avatar
If one injector goes bad, odds are that the rest are not far behind. So you should replace all 6 injectors with new feed tubes. Your contribution test shows that some injectors are not within spec. 10% range is not ideal. Does the smoke smell like diesel?
Old Mar 17, 2024 | 02:17 AM
cholthe's Avatar
I'm way late to this.. but my truck has the same symptoms, you ever figure out what was causing it? Thanks
Powerstroke1995obs
May 30, 2017 05:53 PM
newdieselguy9
12
Mar 14, 2014 10:10 AM
tmcclure
15
Mar 31, 2011 11:46 PM
Gambit
Jan 20, 2011 11:11 AM
MD 91
Chevy/GMC Duramax 01-04 LB7
Jan 14, 2010 11:40 PM
