Oil filter block
Old Apr 4, 2018 | 10:20 AM
Ekvhekvh's Avatar
Default Oil filter block
Forgive my lack of poor terminology, but I’m playing Ring Around the Rosey fixing for oil leaks. Tappet cover and valve towers done. The block on the lower right front which has the oil filter and line to the turbo is leaking below the filter sealing area somewhere. It’s just a cake of old oil now. Transmission is out right now, but when that’s back in, I would like to get this truck house-broke enough to park on concrete and not look a Harley (no offense) convention was there. I will pressure wash and watch but asking in advance for any likely leak areas.
Thanks much in advance for any suggestions.
Eric
Old Apr 5, 2018 | 05:30 PM
JBearSVT's Avatar
It's a 12V, so that's sort of like saying you have little chihuahua you'd like to stop yipping. That said, There's not a whole lot it can be over there so check back after you've pressure washed it off and checked it again.
