Differance in a Dodge 12V and a bus 12V
Old Dec 23, 2017 | 12:19 AM
dieselM715's Avatar
Default Differance in a Dodge 12V and a bus 12V
Hey Guys, I've been hanging around for awhile and I have some questions .
I've been looking for a 12v or a 24v to do a swap into a project. I've been finding some cummins motors out buses or F700 trucks. I was wondering what the differences are with these motors versus one in a Dodge pick up. Attached is a representation of the vehicle that it's going in.
Thanks your input
Old Dec 24, 2017 | 09:22 AM
turbo2332's Avatar
The main issue/difference is that some of the injection pumps in yhe heavier straight trucks had 11mm barrels and plungers. Dodge trucks all have 12mm
Old Jan 7, 2018 | 08:50 PM
dieselM715's Avatar
A lot of the ones I'm seeing have P pumps on them. I don't know if that makes a difference or not. I'm some what new to the diesel world. I've been bitten by the diesel bug and I like it.
The vehicle that this is going into is going to be a camping/tow and just general use rig.
I have one of two 5spds to put in it. One is NV 4500 or a Getrag.
Old Jan 13, 2018 | 03:57 PM
JBearSVT's Avatar
What do the ones that don't have p-pumps on them have? The old rotary style mechanical injection pumps can be turned up too, but generally, the p-pump is the better catch. The NV is a pretty stout handshaker, and doesn't take much to improve unlike the auto's Dodge thought would be fine behind a Cummins. The Getrag could be one of about a half million alternatives, not sure what to say about that option. What's it out of?
Old Jan 14, 2018 | 10:04 PM
dieselM715's Avatar
JBearSVT Thanks for the reply.
The ones that don't have the p-pumps on them I'm guessing they have the rotary pumps. I've been looking at both first and second gens. Also looking into both 12 and 24 valves.
The Getrag that I have is out of a 93 4X4 that had a cummins in front of it, the same for the NV4500. I only have one transfer case for the two. The NV4500 is out of a, I believe to be a 94 4X4.
Old Jan 15, 2018 | 03:53 PM
JBearSVT's Avatar
Either trans should do then. I'd lean towards 12v for conversions, because you can make them run in just about anything. 24v is a little more complicated. And unless the price is hugely different (like, at least a grand more) I'd never take a rotary pumped engine over a p-pump. And to clarify that statement, I'd only take the rotary if it was that much cheaper because then I'd have the money to p-pump it.
Old Jan 19, 2018 | 09:37 PM
dieselM715's Avatar
https://eauclaire.craigslist.org/pts...433622138.html
This is one of the ads for engines in my area that I've been looking at.
Old Jan 20, 2018 | 08:54 AM
JBearSVT's Avatar
Seems to me for that kind of money you aught to be able to find one that didn't come from a bus or have critters living in it for an indefinite number of years, but I've never looked for one.
Old Jan 28, 2018 | 07:04 PM
dieselM715's Avatar
The main thing I'm asking is what's wrong with using one from a bus vs using one from one out of a Dodge pickup ?
Old Jan 28, 2018 | 07:44 PM
JBearSVT's Avatar
Nothing, beyond there maybe being more parts to source to make it work, but based on what it's going in it might make no difference. I believe most of the stuff that bolts on was different between applications, but the 12V is going to pull hard either way.
