OIL LEAK BEHIND TIMING COVER
Old Nov 18, 2017 | 03:42 PM
blue ox's Avatar
Sad OIL LEAK BEHIND TIMING COVER
OK so I just changed my oil and it was very very low did not now i had a bad oil leak entire under side of engine coated with oil, cleaned off front of engine ran truck no leak at idle get rpm around 2000 for about 2-4 minutes jump out and look oil is leaking from timing cover housing left side front of engine , how do you fix this leak ? how do you remove timing housing from block, is this a major repair what is aprox cost?
Old Nov 27, 2017 | 07:45 PM
51Hudson's Avatar
Have you tabbed your KDP?
Old Nov 28, 2017 | 04:38 AM
JBearSVT's Avatar
Are you sure it isn't the crank seal? That's very common.
Old Nov 30, 2017 | 09:13 PM
RedChevy44's Avatar
You have to pull the cam to remove the timing housing. It gets pretty involved. A job best left to a competent mechanic. You don't want to accidentally drop a lifter to the oil pan.
Old Mar 31, 2018 | 09:15 AM
windage's Avatar
blue ox...how did you handle this issue? lots of vids on tricks to retain lifters using wood dowels..may be the path I take to replace front seal in my 12v
Old Mar 24, 2019 | 12:23 PM
windage's Avatar
it's been a year, I just noticed, since I posted this reply/question to Blue Ox...meanwhile, I did my KDP, front seal, pump timing..(injectors, deliv valves, AFC live/max travel kit, 4k gov springs from Power Driven Diesel and gauges)...hope he got his issue resolved..
Old Mar 25, 2019 | 06:03 PM
JBearSVT's Avatar
Nice, man. The PDD guys are good people. I loved dealing with them.
dango
Jun 21, 2016 01:13 PM
acesneights1
12
Jan 16, 2013 09:02 AM
DieselDan98
9
Nov 30, 2010 04:49 AM
Neibe
Nov 3, 2010 06:44 PM
oglejust
5.9L 12V Performance
18
Jan 20, 2009 03:50 AM
