Fuel Pressure Regulator Fix
Old Oct 13, 2017 | 09:01 PM
DWSchwefel's Avatar
Default Fuel Pressure Regulator Fix
Truck: 95 F350, 315K miles. Intercoller installed.
Engine: 01 E350 Converted to fit the 1995 truck.
I have the E350 fuel pump mounted on the chassis rail, tanks are 100% clean, I have a filter before the fuel pump. THe fuel pump is new. I normally run 65psi on fuel pressure. I have a gauge in the cab.
Lately, under hard acceleration my fuel pressure, FP, will drop to 20psi, then 0 psi, then start to run rough.
I took the fuel pressure regulator, FPR, apart and installed a new piston and a blue spring. The old piston was very dirty and sticky. The schematic that I will attach ......shows an o ring and a piston seat, number six and seven in the diagram. I did not remove these old items. I tried to get them out with a pick, I left them in place. The old piston did have a very small o ring around the cylinder seated on the piston's shoulder. I put this new o ring on the new piston and re-inserted the piston and the spring and the cover.
I started the truck and I now have 90 psi at idle.
I think something is wrong.........ideas?
Thnx
DaveS
Old Feb 27, 2023 | 05:54 AM
revev3's Avatar
Thnx
DaveS
I knw this is an old post but what did you do to fix the high fuel pressure issue after rebuilding the FP regulator? I'm having the same problem now. thx
RattleBomb7.3
24
Mar 19, 2012 01:06 AM
99stackedpowerstroke
6.0L Performance
Nov 14, 2011 10:19 PM
stephenjr
Apr 17, 2010 11:37 AM
LOGANSTANFORTH
94-98 7.3L Powerstroke Tech Articles
Jan 17, 2010 03:42 AM
DslDeamon
Dec 9, 2009 03:37 PM
