Transmission suddenly running HOT!
Old Aug 27, 2017 | 10:42 AM
DodgeDieselFan's Avatar
Default Transmission suddenly running HOT!
Hi all:
I'm new the forum and I've been having an issue with my transmission running hot. I've look through the previous post and saw a few very good suggestions but non have worked for me so far. Here's the issue:
I have a 2007 dodge 5.9 with the 48re transmission with a deep oil pan. I have a Edge CTS programmer and a few months ago the trans temp reading went up between 20 - 30 degrees (2008 -212 degrees - normal driving). My normal temp was around 185 - 188 degrees. These temps are with no load. Outside temp around 105. I generally pull a 13K fifth wheel trailer and I've only seen these temps when in heavy traffic, in town going extremely slow speeds. Here's what I've done so far:
1 - had the fan clutch replaced - mechanic said the fan was not keeping up to speed. Dodge OEM fan. It was pricey!
2 - disabled the trans cooling fan thermostat and flushed radiator - was a solution found on this forum (thanks) but did not solve the problem
3 - took the truck to a transmission shop thinking I might have a torque converter issue - no problem found with the trans.
4 - purchase an IR thermometer to confirm the trans. fluid temp. in the pan - temp was within 10 degrees (IR +- 2%) of what was displayed on the CTS No issues with engine coolant temp. Cooling temp stays between 197 -200 degrees max.
Not sure what I should focus on next so I'm looking for other suggestions and HELP! I'm getting desperate to solve this problem since I have a big trip planned for next month. Any help or suggestion will be appreciated.
Old Aug 28, 2017 | 11:30 AM
chopforeman's Avatar
To me it sounds like your tranny cooler it plugged.
Not getting any air flow or proper oil flow.
replace it with a bigger aftermarket one
Old Aug 28, 2017 | 05:42 PM
chopforeman...I appreciate the reply but I did flush the oil to air trans. radiator and it flowed well. Unless your referring to the oil to coolant radiator?
Do you know if dodge makes a larger trans. cooler radiator? It was suggested by a friend that I replace the stock radiator with a ford 7.3 type radiator. However it would required making some type of new brackets etc.
What's your thoughts on adding a powered aux. cooler in line with the stock cooler?
Thanks
Old Aug 29, 2017 | 10:08 AM
I am talking tranny cooler these trucks have a tranny cooler on them I bet the air flow is poor.
Old Aug 29, 2017 | 07:24 PM
chopforman's Avatar
i think a aux tranny cooler would be a good idea.I am thinking of installing one this winter in my diesel.
because it goes from moter
rad
tranny cooler
intercooler
ac condensor
Old Aug 29, 2017 | 08:39 PM
thanks chopforman...I'm looking into the possibility that I have a bad trans. sensor? I'm also getting a quote to get a powered aux cooler installed. I'll keep you and everyone who read this post know how I make out.
