Bucking, missing, pinging, black smoke. Help
Old Jul 22, 2017 | 12:18 AM
Keeth Colton's Avatar
Default Bucking, missing, pinging, black smoke. Help
I'll do so searching, but if anyone wants to chime in directly I would appreciate it. 2006 Ram 2500 all stock with the exception of Exhaust, cold air intake, and Edge EZ. 243k miles....
Sooo driving back home to Oregon today from Nor-Cal all is doing great as usual until major run ability problems. Here where the conditions. Cruise control set @ 70mph, 90 degrees outside, just above 1/4 tank fuel remaining since fill up in Willitis Ca. Running empty NOT hauling or towing.
So here's what happened. was blasting along, than than a huge kick like a massive cyl dump miss, than starts bucking and missing bad, starts pinging real bad, I cancel the cruise and give it 3/4 throttle the truck takes off into run-away mode gets to 85mph , large black smoke. I was about to shut the key off when it stops and calms down, but still missing. So I look at my traffic conditions and decide to lay into see see what happens, I go WOT and get a huge plume of black smoke again and massive detonation(pinging), bucking, cutting out, and again run-a-way. If i brought it down under 60 and low pedal maintenance she cruised fine, but the moment it's put under a load or heavy pedal all would start again, I was able to make it home, but there is a problem. No check engine light, no funny warning lights, water temp normal, oil level normal, and oil pressure normal.
So If anyone knows of a thread here on this please share with me or let me know your thoughts. Thanks
Old Jul 22, 2017 | 09:18 AM
CumminsCoalRoller24/7's Avatar
What level was the edge set to? Do you have a rail pressure gauge? Not sure about pinging noise, could have been a side effect of running rough but my guess is the lift pump is taking a dump and can't keep up with fueling. Have you replaced your lift pump yet?
Old Jul 22, 2017 | 10:39 AM
Haven't done anything yet, I don't know what direction to go in. The edge is just a EZ so it has a 3way toggle switch. I've never changed it. It's on the middle position which I believe is +100. I don't have any gauges other than the factory. Where is the lift pump located?
Old Jul 22, 2017 | 12:20 PM
Okay, update... Figured i would remove the Edge Ez first to eliminate it as a problem... Well guess what took a ****.. Yep truck now runs great and all is well.. Edge EZ, meet the trash can.
Old Jul 22, 2017 | 08:59 PM
That's the best spot for it. Do yourself a favor and get EFI Live!
Old Jul 22, 2017 | 10:29 PM
chopforman's Avatar
If your going to buy a tuner buy a smarty jr.
The support staff at smarty are so good and helpful
They will help you tune your truck the right way
Old Jul 23, 2017 | 05:22 PM
06+ TrUcks EFI Live offers the best tuning available
