No Charging system, no tach, no wait to start
Old Dec 29, 2016 | 09:40 PM
Andyhc1's Avatar
Default No Charging system, no tach, no wait to start
Ive been chasing this problem for months now. No charging system, no tach, no wait to start, no speedo and about out of money . Ive replaced cps, batteries, alternator, pcm, and chased down seems like 1000 wires. And advice will be greatly appreciated im out if ideas.
Old Dec 30, 2016 | 09:03 AM
Diesel.121's Avatar
Have you tried driving it since this started or has it been parked? Is it an automatic or manual transmission?
Old Dec 30, 2016 | 09:50 AM
Andyhc1's Avatar
Ive driven it 2 or 3 times since it started all this ( enough to drain the batteries) . And its a manual transmission
Old Apr 14, 2017 | 10:58 PM
Mahir Sa'id's Avatar
im having the same problem it would be nice for someone to help us out
Old Apr 15, 2017 | 05:18 AM
JBearSVT's Avatar
Dash harness
Old Apr 16, 2017 | 09:48 PM
Andyhc1's Avatar
Default Figured it out
I actually figured it out a couple months ago. A wire had gotten pushed out of the back of the fuse panel goin to the main "engine" fuse or somethin like that. Kinda feel like a D.A for not finding it before i put all that money in it, but hey live and you learn right?
Old Apr 17, 2017 | 04:51 AM
JBearSVT's Avatar
Seriously? How the...? Hm. Interesting.
Old Apr 19, 2017 | 08:08 PM
Andyhc1's Avatar
I had installed an airdog and it runs into the fuse block. I guess when i hooked it up the first time i pushed the wire out. Kind of a one in a million thing i guess
Old Apr 20, 2017 | 04:48 AM
JBearSVT's Avatar
Yeah, I'd never heard of that before. One more for the lists.
Old May 22, 2017 | 10:56 AM
Here4thecake's Avatar
I have bun chasing this same issue for a week. Same symptoms: no tach, a/c, O/D or torque lock up, alt isn't charging. I first swapped out the Ess. With proper gapping it still hasn't fixed the problem. I started chasing other sensors and found my tps had some torn wires at the connector. Replaced that with no luck. I am receiving signal and power at both sensors 8.8 and 3.8 respectively. I have also been checking grounds and continuity wherever I can. Does anyone have any advise!? I'm a patient person but this is getting old. Would the PCM be bad and still be sending power and signal?
