Passenger Vehicles General Discussion General Diesel Discussion of all Passenger Vehicles with Diesel Engines
Mitsubishi Lancer 1.8 Turbo Diesel Intercooler Fitting
Old Jun 4, 2008 | 05:46 AM
lancerevodiesel's Avatar
Default Mitsubishi Lancer 1.8 Turbo Diesel Intercooler Fitting
Hi. I have a 1990 Mitsubishi Lancer 1.8 turbo diesel 4d65 with a td04-09b turbo. I just fitted a front mounted intercooler & the boost pressure was reduced to 7 psi from 9 psi. Is this normal or is there something wrong? I had fitted a boost controller to turn the boost up to 10 psi. Also tested the piping for leaks and everything was ok with no leaks. I Also noticed more whistle coming from the cone filter. Is this normal?
Thank you very much.
Old Jun 4, 2008 | 01:05 PM
2500HeavyDuty's Avatar
Its it normal sometimes you do loose boost from addind an intercooler since it it restrictive. But the cooling benefits are much better.
I bet you also have your boost tap on the cool side (engine side) of the intercooler too.
Old Jun 4, 2008 | 02:25 PM
Benjamin's Avatar
Bombardier
even though it is a couple pounds lower does it feel stronger?
Old Jun 4, 2008 | 05:12 PM
Yes at the same boost levels as before 9 psi it feels stronger but there is a little lag.
Thank you for your posts
Old Jun 5, 2008 | 12:07 AM
are your egts lower?
Old Jun 5, 2008 | 02:28 AM
I don't know about egt's because, I am still wating for the gauge.
Old Jun 5, 2008 | 02:54 AM
well they most likely are, whats next on the bomb list
Old Jun 5, 2008 | 03:29 AM
Because of the fitting of the intercooler, I changed the intake manifold to the non turbo intake manifold which is much bigger than the turbo manifold. I did this because the non turbo intake manifold has a bigger inlet hole (60mm) and the turbo manifold was (40mm) Is this good?
Thanks
Old Jun 5, 2008 | 03:36 AM
if there aren't any leaks i don't see why there would be a problem, do you have any pics of these manifolds?
Old Jun 5, 2008 | 08:58 PM
Benjamin's Avatar
Bombardier
Thanks
if i was a betting man i'd say that that is where you lost 2 pounds of boost. with that big of a difference there is less resistance and therefore less boost.
