Rattle/ticking noise from 1600-2200 rpms
Old Nov 10, 2016 | 04:53 PM
Heath.hulsey's Avatar
Default Rattle/ticking noise from 1600-2200 rpms
I have a 2007 5.9 that has been making a ticking noise for some time now but has gotten worse lately. Best way I can describe the noise is an exhaust leak but we have pressure tested the engine and can find no leaks anywhere. I have put new injectors (due to a starting issue, all 6 tested bad with high return pressure) new fca, and new rail pressure sensor on with no change in the sound. The sound starts around 1600 and goes to about 2200 rpms. As soon as you mash in the clutch or let off the accelerator (take the load off the engine in any way) the noise instantly goes away. Not throwing any codes. The truck has 100 horse injector tips, smarty TNT, afe cold air intake, banks high ram intake horn, valair dual disk clutch, and an air-dog 150 lift pump. Any help would be GREATLY appreciated it's about to drive me crazy!!
Old Nov 11, 2016 | 05:29 AM
tlevan03's Avatar
are you getting any vibration or just the noise? Im in very deep thought over this at the moment.
Old Nov 11, 2016 | 06:50 AM
No vibration just the noise
Old Nov 12, 2016 | 12:45 PM
tlevan03's Avatar
https://www.dieselbombers.com/5-9l-c...ick-noise.html
check this out. Ive been thinking, but can't come up with an idea of what it could be
Old Nov 13, 2016 | 04:04 PM
CumminsCoalRoller24/7's Avatar
Have you checked exhaust manifold bolts? I think I read something similar to this a while back and one of the manifold bolts was slightly loose- check and double check!
Old Nov 13, 2016 | 07:26 PM
dangerous1965's Avatar
Clutch ?!
