oil pan replacement
Old Oct 22, 2016 | 12:52 PM
tanda603's Avatar
Default oil pan replacement
my oil pan finally let go and was wondering if anyone had replaced theirs and how was it and what kind did you use oem or aftermarket
Old Oct 22, 2016 | 08:35 PM
CumminsCoalRoller24/7's Avatar
I haven't done mine yet but would recommend Geno's before the dealer! They have factory and stainless options
https://www.genosgarage.com/category/s?keyword=Oil+pan
Old Oct 23, 2016 | 10:04 AM
123's Avatar
123
Default 6.7 oil pan
I replaced mine on my 2008 6.7 it was a pretty easy job actually
I'm thinking it would be pretty much the same
You don't have to pull the motor like the dealer or some guys say
Old Oct 25, 2016 | 01:55 PM
captaindean's Avatar
i just did mine on Saturday like everyone says its not that difficult
1 Drain oil and remove air filter assembly disconnect batteries
2 remove the 2 bolts that hold the fan shroud
3 loosen the 2 motor mounts
4 rig up a chain between the hook on passenger side of motor and i used a bolt on the left side of the head just in front of intake horn
5 remove all pan bolts except 4
6 raise engine untill the valve cover touches the top of the engine bay
7 use jack stands to brace motor up i put mine on top of the front differential
Old Oct 31, 2016 | 04:01 PM
tanda603's Avatar
thx for the advice, gonna try it this week
