lookin for some info .
Old Jun 16, 2016 | 02:46 PM
mgil's Avatar
Default lookin for some info .
first is there a list of how many and what size lamps are on my 92 dodge d250 , i want to upgrade the whole truck to leds? and also i have the truck with the o/d button and the transmission that downshifts when you floor it is there any way to bypass that arrangement ? it can get really annoying after a while . thanks for your help
Old Jul 16, 2016 | 03:44 PM
manvstaco's Avatar
I regards to the trans downshifting, try to adjust your Transmission control cable up by the fuel pump and throttle linkage. If I remember it right bringing the cable towards the front of the truck will keep it from downshifting as often, other direction makes it DS more often.
Old Jul 16, 2016 | 09:22 PM
MasterG73's Avatar
check out lmc truck for led lights, if you mash the petal in OD you want it to down shift, OD is not a gear you want all that torque to be hitting, but there is a procedure to adjust the down shift cable, i would start buy looking up that procedure
Old Jul 17, 2016 | 06:07 AM
mgil's Avatar
thanks for the replies , i also have seen a tps delete kit which puts a rheostat i think in the cab so you can adjust the od shift point . i just found some write ups on this and im gonna give it a try thanks again
