Begle's Water Fumigation
Old May 28, 2008 | 05:05 PM
Begle1's Avatar
Default Begle's Water Fumigation
Computer programmable 7-stage boost/ EGT/ RPM-referenced water/ methanol fumigation.
Work in progress.
1stGen.org :: View topic - Begle's Water Injection
Old May 28, 2008 | 05:29 PM
DB Admin's Avatar
Banned
WOW thats pretty innovated !
Old May 28, 2008 | 05:32 PM
Benjamin's Avatar
Bombardier
do you have a picture of the water coming out of the nozzle? i'd be interested in seeing the spray pattern.
Old May 28, 2008 | 05:46 PM
Begle1's Avatar
It's a well atomized cone, around 130 degrees. I wasn't able to take any pictures with my test rig, and it's too much of a pain to pull the nozzles out and build a new one...
Old May 28, 2008 | 05:49 PM
Benjamin's Avatar
Bombardier
what is the flow rates per nozzle and where did you get them. i've never seen that style...
Old May 28, 2008 | 05:54 PM
Begle1's Avatar
1stGen.org :: View topic - Fogger water-meth nozzles
6.6, 12.6 and 26.4 GPH at 100 PSI. I seem to be actually getting quite a bit lower. I need to put a pressure gauge on my water pump to see what it's actually putting out at 40 GPH; I suspect that it's dropping a bit low.
Old May 28, 2008 | 06:08 PM
Benjamin's Avatar
Bombardier
remember that whatever boost pressure you are running needs to be subtracted from the pump pressure. so if the pump is putting out 100psi and you are boosting 35psi then you are only getting roughly 65psi though the nozzle..... now what a few guys with gassers that i know do is make sure the water resivoir is completely sealed and put a boost reference on the water tank. therefore it'll negate the boost affect in the intake.... you'll have 35 psi blowin into the 100psi pump..... do you see what i'm tryin to say? it sounds better in my head than it does in type.....
Old May 28, 2008 | 06:09 PM
Begle1's Avatar
Yeah, I got that part.
I still need to get a pressure reading on one of the water lines.
Old May 28, 2008 | 06:13 PM
Benjamin's Avatar
Bombardier
ya you do have a ton of volume there.....
Old May 28, 2008 | 06:35 PM
dozerboy's Avatar
Thats a nice setup Is this for power and EGTs while towing or just more power?
